Opening text editor in Quartus Prime Pro
My project consists of only one AHDL text file. How do I open a text editor to be able to type in this TDF? Sorry for this basic question; just starting Quartus, however I did a lot of AHDL in the past. Thanks
Issue resolved!
My file had a double extention <name>.TDF.txt Ater removing .txt, it was recognized by Quartus.
Thanks Sheng
- HansHolland
Shouldn't be too hard and too much to ask. Want to type-in TDF to get a config. bit stream produced. Failed using my own text editor and use "add design file" or something, trying to find example tutorial, etc. etc.
- ShengN_altera
Hi HansHolland,
If I'm not mistaken, you want to open the .tdf file and then edit it with Quartus pro right?
- Click the "File" at the top bar of Quartus pro, click ''Open'', select .tdf file type and open your own TDF file.
- Or straight click the ''Open'' located at bar below.
- Or click the ''Files" near ''Project Navigator'' window, double click it, click ''...'', select your TDF file, click ''Apply'' and click ''OK''. Double click the added file to open text editor.
Hope it helps.
Sheng
- HansHolland
Hi Sheng,
Option 3. you mention, results in "Can't find design entity <filename>" error. I cán see my TDF in the Quartus editor.
Trying to compile, results in "Top-level design entity <filename> is undefined" error.
- ShengN_altera
Hi HansHolland,
Make sure that TDF is set as top level entity by right-clicking that file and click ''Set as Top-Level Entity''.
Also, make sure filename matched with the name after module.
Sheng- HansHolland
Issue resolved!
Thanks Sheng
