HansHolland
4 years agoOpening text editor in Quartus Prime Pro
My project consists of only one AHDL text file. How do I open a text editor to be able to type in this TDF? Sorry for this basic question; just starting Quartus, however I did a lot of AHDL in the pa...
- 4 years ago
Issue resolved!
My file had a double extention <name>.TDF.txt Ater removing .txt, it was recognized by Quartus.
Thanks Sheng
HansHolland
4 years agoShouldn't be too hard and too much to ask. Want to type-in TDF to get a config. bit stream produced. Failed using my own text editor and use "add design file" or something, trying to find example tutorial, etc. etc.
- ShengN_altera4 years ago
Hi HansHolland,
If I'm not mistaken, you want to open the .tdf file and then edit it with Quartus pro right?
- Click the "File" at the top bar of Quartus pro, click ''Open'', select .tdf file type and open your own TDF file.
- Or straight click the ''Open'' located at bar below.
- Or click the ''Files" near ''Project Navigator'' window, double click it, click ''...'', select your TDF file, click ''Apply'' and click ''OK''. Double click the added file to open text editor.
Hope it helps.
Sheng
