OpenCL environment for darby nodes on devcloud
I have been running OpenCL applications on the devcloud intel_a10gx_pac boards for several months now. I was recently granted access to the two "darby" nodes (intel_s10sx_pac), nodes s001-n189 and s005-n008. However, when I log in interactively to node s001-n189, for example, and try to run aoc or aocl, they're "not found". On the arria10 nodes, one's environment was set up properly such that all the software and board models were accessible by default. That appears not to be the case for the darby nodes. Can someone please tell me how I should set up my environment to be able to run?
Thank you!
- AnilErinch_A_Intel
Hi ,
Hope the issue is resolved after discussions with the team.
Thanks and Regards
Anil
- JSchr20
Thank you, yes, my environment was successfully set up and I have been able to emulate and build hardware successfully.
Here's a summary of my notes on how to make it work at this time. This is how I'm able to build an OpenCL design that wraps System Verilog RTL which in turn wraps encrypted VHDL 2008 RTL (which requires a local modification to the BSP):
For the darby nodes using devcloud_login, the batch job.sh looks like this (note fully-qualified paths):
#!/bin/bash
source /data/intel_fpga/devcloudLoginToolSetup.sh
tools_setup -t S10DS
aoc -board-package=/home/u40073/intel_opencl_bsp_pac_s10_dc_local -board=pac_s10_dc -DNUM_COMPUTE_UNITS=1 -DNUM_LIMBS=4 -DNUM_INTS=8 /home/u40073/calculator_s10/mult_multi_limb_wide/device/mult_multi_limb_rtl.cl -o /home/u40073/calculator_s10/mult_multi_limb_wide/bin_monster_1_4_8/mult_multi_limb_hw.aocx -I /home/u40073/calculator_s10/mult_multi_limb_wide/rtl/lib -I /home/u40073/calculator_s10/mult_multi_limb_wide/device -L /home/u40073/calculator_s10/mult_multi_limb_wide/rtl -l mult_multi_int_lib_monster.aoclibTo then run that job in batch mode:
devcloud_login -b S10PAC job.sh # submit the job
qstat batch@v-qsvr-fpga # check for jobs
watch -n 1 qstat -n -1 batch@v-qsvr-fpga # watch the job
qdel 7321.v-qsvr-fpga # example of deleting a darby jobIf you get a CL_DEVICE_NOT_FOUND error, you might be able to work around it by just loading the bitfile by hand:
aocl program acl0 <project>.aocx
Then just run the host code as normal.Thanks again for all of your help.
- DDIAKITE
How did you set up the tools on the s10 nodes?
"tools_setup -t S10DS" works fine to set them up when you are logged interactively.
Regards!
- JSchr20
Hi DDIAKITE, thanks for your reply. Unfortunately, "tools_setup" is not found when I log in interactively. (See transcript below.) Can you please give me the full path to that command, so that I can try forcing a run of that command?
Thank you!
Transcript:
u40073@login-2:~$ qsub -q batch@v-qsvr-fpga -I -l nodes=1:darby:ppn=2 -d .
qsub: waiting for job 7103.v-qsvr-fpga.aidevcloud to start
qsub: job 7103.v-qsvr-fpga.aidevcloud ready
# Date: Fri Jul 17 09:55:47 PDT 2020
# Job ID: 7103.v-qsvr-fpga.aidevcloud
# User: u40073
# Resources: neednodes=1:darby:ppn=2,nodes=1:darby:ppn=2,walltime=06:00:00
########################################################################u40073@s005-n008:~$ tools_setup -t S10DS
-bash: tools_setup: command not found- DDIAKITE
Hi JSchr20,
Try those command:
tools_setup -t S10DSIf it works then you should add the following in your bashrc:
if [ -f /data/intel_fpga/devcloudLoginToolSetup.sh ]; then
fiAnd after that "tool_setup" will be found anytime without sourcing devcloudLoginToolSetup.sh manually.
Regards!
