OpenCL environment for darby nodes on devcloud
How did you set up the tools on the s10 nodes?
"tools_setup -t S10DS" works fine to set them up when you are logged interactively.
Regards!
Hi DDIAKITE, thanks for your reply. Unfortunately, "tools_setup" is not found when I log in interactively. (See transcript below.) Can you please give me the full path to that command, so that I can try forcing a run of that command?
Thank you!
Transcript:
u40073@login-2:~$ qsub -q batch@v-qsvr-fpga -I -l nodes=1:darby:ppn=2 -d .
qsub: waiting for job 7103.v-qsvr-fpga.aidevcloud to start
qsub: job 7103.v-qsvr-fpga.aidevcloud ready
# Date: Fri Jul 17 09:55:47 PDT 2020
# Job ID: 7103.v-qsvr-fpga.aidevcloud
# User: u40073
# Resources: neednodes=1:darby:ppn=2,nodes=1:darby:ppn=2,walltime=06:00:00
u40073@s005-n008:~$ tools_setup -t S10DS
-bash: tools_setup: command not found
- DDIAKITE6 years ago
Hi JSchr20,
Try those command:
source /data/intel_fpga/devcloudLoginToolSetup.sh
tools_setup -t S10DSIf it works then you should add the following in your bashrc:
if [ -f /data/intel_fpga/devcloudLoginToolSetup.sh ]; then
fiAnd after that "tool_setup" will be found anytime without sourcing devcloudLoginToolSetup.sh manually.
Regards!
- JSchr206 years ago
Thank you! That has improved matters, but my code still does not run, possibly due to the gcc version I'm using in my host code (I need access to gmp). I will look more into that and perhaps I can get something sorted out. I at least have tools_setup running now.
- AnilErinch_A_Intel6 years ago
Hi
Please let us know which gcc version you are using , and whether you are able to run the code now.
If not please let us know the error message which you are seeing while trying to compile/execute the code.
Thanks and Regards
Anil
