oneAPI on Cyclone10gx
@whitepau_alterathe simulation does work. I will edit the sample dma to actually do something useful rather than copying/comparing elements. You mentioned I will have to use the nios tools to connect to the soft core; however I was planning on running my code on the computer CPU with some part of my algorithm memory mapped to an IP that will result from oneAPI compiler. So in this case, if I understand correctly, I don't need to connect to the niosV (unless I want to inspect/debug), am I right?
thanks!
I successfully synthesized the niosV example (as it is), adding this top node:
library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.NUMERIC_STD.ALL; entity test_system is port ( clk : in STD_LOGIC; rst : in STD_LOGIC ); end entity test_system; architecture Behavioral of test_system is component pd_system is port ( clk_clk : in std_logic := 'X'; reset_reset : in std_logic := 'X'; simple_dma_accelerator_device_exception_bus_data : out std_logic_vector(63 downto 0) ); end component pd_system; signal pd_system_clk : std_logic; signal pd_system_rst : std_logic; begin u0 : pd_system port map ( clk_clk => pd_system_clk, reset_reset => pd_system_rst, simple_dma_accelerator_device_exception_bus_data => open ); pd_system_clk <= clk; pd_system_rst <= rst; end architecture Behavioral;
However when I tried (a few things) to run the software companion produced by oneAPI I got:
tetto@ubuntuoffice:~/oneAPI-samples/DirectProgramming/C++SYCL_FPGA/ReferenceDesigns/niosv/kernels/simple_dma/build$ ./simple_dma.fpga Running on device: SimulatorDevice : Multi-process Simulator (aclmsim0) terminate called after throwing an instance of 'sycl::_V1::runtime_error' tetto@ubuntuoffice:~/oneAPI-samples/DirectProgramming/C++SYCL_FPGA/ReferenceDesigns/niosv/kernels/simple_dma/build$ tetto@ubuntuoffice:~/oneAPI-samples/DirectProgramming/C++SYCL_FPGA/ReferenceDesigns/niosv/kernels/simple_dma/build$ sudo ./simple_dma.fpga [sudo] password for tetto: ./simple_dma.fpga: error while loading shared libraries: libdspba_mpir.so.23: cannot open shared object file: No such file or directory tetto@ubuntuoffice:~/oneAPI-samples/DirectProgramming/C++SYCL_FPGA/ReferenceDesigns/niosv/kernels/simple_dma/build$ sudo LD_LIBRARY_PATH=$LD_LIBRARY_PATH ./simple_dma.fpga terminate called after throwing an instance of 'sycl::_V1::runtime_error' what(): No device of requested type available. Please check https://software.intel.com/content/www/us/en/develop/articles/intel-oneapi-dpcpp-system-requirements.html -1 (PI_ERROR_DEVICE_NOT_FOUND) Aborted tetto@ubuntuoffice:~/oneAPI-samples/DirectProgramming/C++SYCL_FPGA/ReferenceDesigns/niosv/kernels/simple_dma/build$
Coming back to this example, I was also playing with:
oneAPI seems to produce a quartus project completed with the top node (that I can compile and synthesize), but again when I run the executable I encounter a runtime error. In that vector_add.src it seems this "unified memory" would just do the job, but I recall you mentioned earlier one has to edit the RTL design (although in this part3 the top node seems properly generated and needed IPs/avalon devices are there and instantiated).
- whitepau_altera2 years ago
Contributor
Stefano, let me refer you once again to this comment: https://community.intel.com/t5/Intel-High-Level-Design/oneAPI-on-Cyclone10gx/m-p/1573813/highlight/true#M3497
The code you got from the code sample is the dark green boxes in this picture (Host code and Application Kernel). without all the other stuff in the middle, that generated executable file will not work.
The executable that oneAPI emits will not work without a supported BSP. Since you have selected -Xstarget=Cyclon10GX, you have created an IP, which is just the Application Kernel in that picture. This means that when you use the Application Kernel, it is treated like any other IP that was written using Verilog or VHDL.
To 'run' your IP, you will need to program the Nios-based design you created onto your board and execute Nios code to control the IP.oneAPI seems to produce a quartus project completed with the top node (that I can compile and synthesize), but again when I run the executable I encounter a runtime error. In that vector_add.src it seems this "unified memory" would just do the job, but I recall you mentioned earlier one has to edit the RTL design (although in this part3 the top node seems properly generated and needed IPs/avalon devices are there and instantiated).
That generated Intel® Quartus® Prime project is only for estimating fMAX of your IP. The point of it is to assign the pins of the IP to virtual pins so that Intel® Quartus® Prime will place and route it without actually connecting it to physical pins. Here is an explanation of virtual pin assignments https://www.youtube.com/watch?v=QET0lC-jdAQ
If you wish to build a custom BSP so that you can install your C10GX PCIe card into a computer and communicate with it through the OpenCL runtime (and have oneAPI host code control it), we have guidance on custom BSP creation here:
Getting started : https://ofs.github.io/latest/hw/common/user_guides/oneapi_asp/ug_oneapi_asp/
Reference Manual: https://ofs.github.io/latest/hw/common/reference_manual/oneapi_asp/oneapi_asp_ref_mnl/
