No JTAG hardware available for Quartus prime pro 19.1.0.240
After install the QUARTUS PRIME PRO 19.1.0.240 software, when i run the command : jtagconfig, it says"No JTAG hardware available"
- The soluation :
$ sudo killall -9 jtagd
$ sudo jtagd
still not work(link at altera web:https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/embedded/2018/why-do-i-get-the-error-no-jtag-hardware-available-when-running-j.html)
2 I switch to other quartus prime pro 18.1(both installed on my pc), and run the command :jtagconfig, it's OK
Anybody can help me fix the jtag problem for quartus prime pro 19.1.0.240????
Hi zjinf,
I believe you are using USB-Blaster II. There is some issue with USB Blaster II when using Quartus 19.1 version. Please follow the following KDB for workaround.
https://www.intel.com/content/altera-www/global/en_us/index/support/support-resources/knowledge-base/component/2019/why-does-my-usb-blaster-ii-not-work-when-using-intel--quartus---.html
I hope this will help.
Thanks😉
- ShafiqY_Intel
Hi zjinf,
Thanks😉
