zjinf
7 years agoNo JTAG hardware available for Quartus prime pro 19.1.0.240
After install the QUARTUS PRIME PRO 19.1.0.240 software, when i run the command : jtagconfig, it says"No JTAG hardware available" The soluation : $ sudo killall -9 jtagd ...
- 7 years ago
Hi zjinf,
I believe you are using USB-Blaster II. There is some issue with USB Blaster II when using Quartus 19.1 version. Please follow the following KDB for workaround.
https://www.intel.com/content/altera-www/global/en_us/index/support/support-resources/knowledge-base/component/2019/why-does-my-usb-blaster-ii-not-work-when-using-intel--quartus---.html
I hope this will help.
Thanks😉
