Msgdma extended descriptor ignoring the lsb [32-63] address
HI,
I am using Msgdma memory mapped to Stream (in AGILEX -f agfb014r24b2e2v )(MM2S) with extended descriptor when i write the Descriptor and trigger the Dma data is streaming from the address of MSB (0x0 offset )
for example :
I am write some dummy data in address 0x1160000000
in 0x0 offset writing 0x60000000
in 0x14 offset writing 0x11
and triggering the dma but when i check in sys tap analyser data is streaming which is present in
0x60000000 only and ignoring msb
- hareesh
can you share your platform design?
- madhan_m
- hareesh
- madhan_m
hi,
i am using qsys_top.qsys
- hareesh
if you see here you didn't used SSBIN line. connect that line
- madhan_m
hi,
i am not using that ip. you can delete it
i checked connecting it but it is not working
- hareesh
Can you please enable bellow shown option?
- madhan_m
hi,
i tried with that setting but it is not working
- hareesh
https://community.intel.com/t5/FPGA-Wiki/MSGDMA-design-example/ta-p/735335?wapkw=msgdma
please try this example project of MSGDMA.
in attached folder you can find out all drivers(software folder) and platform design.
Thank you,
- hareesh
