madhan_m
3 years agoMsgdma extended descriptor ignoring the lsb [32-63] address
HI,
I am using Msgdma memory mapped to Stream (in AGILEX -f agfb014r24b2e2v )(MM2S) with extended descriptor when i write the Descriptor and trigger the Dma data is streaming from the address of ...
hareesh
3 years agoHi,
if you see here you didn't used SSBIN line. connect that line
