Gopikrishnan
5 years agoMemory error when trying to simulate matrix multiplication using HLS math lib
component void test(ihc::stream_in<int> &matrixData,ihc::stream_in<int> &matrixData2,ihc::stream_out<int> &matrixout,bool ld,
int dim_in,int dim_out){
////////////input and outp...
BoonBengT_Altera
Moderator
5 years agoHi @Gopikrishnan,
Thank you for posting in Intel community forum, hope all is well and apologies for the delayed in response.
Would recommend to try on the loop unroll pragma, which should reduces the latencey.
More information can be found here on the code snippet and implementation.
Please do let us know if that helps.
Note: there are also details steps on the loops best practices here which are recommended, hopefully it will give some insights.
Best Wishes
BB
