max_concurrency: scheduled at run-time or compile-time?
- 3 years ago
Hey @xwuupb
Changing the concurrency of the loop changes the hardware that gets produced. So this is a compile time change.
Reducing the concurrency of a loop reduces the resource usage for that loop (because it needs to be able to handle fewer concurrent iterations).
Now it is called "max_concurrecy" and not "concurrency" for a reason.
Your loop may now not have a new iteration ready to execute at each cycle.
This may be due to different reasons such as a blocking pipe read or any upstream component that stalls your loop.
So there is also a run-time aspect to how loop iterations are scheduled.
The reason why you can't find the exact answer you are looking for is because it would not make sense to artificially limit the concurrency of a loop at runtime.
If you have the hardware that allows you to interleave as many iterations as possible, there is no reason to limit it at run time.
So the entire point of this attribute is to tell the compiler that it can limit the maximum concurrency because you know that the consumer of that the result being computed in this loop does not require the result to be computed so fast.
Therefore, you can make hardware savings by limiting the max concurrency (compile time).
The page linked above by @hareesh says "The max_concurrency attribute enables you to control the on-chip memory resources required to pipeline your loop." which implicitly tells you this is done at compile time.
1) Is the loop with this directive scheduled at run-time on FPGAs or compile-time by the compiler?
Answer: max_concurrency attribute are implemented to pipeline the loop for singel task kernel, hence my guess it would be programme to execute in the hardware runtime to provide an estimation of area used.
2) But it's not very clear, whether the iterations in the loop are dynamically scheduled at run-time, or scheduled already at compile-time, or other possibilities?
Answer: as mention above.
More details explaining the functionality of the attributes can be found in the link below:
Hope that clarify.
Hi, thanks for your answers.
Do you have additional references or manuals (besides the link you give below) for it? "my guess ... " sounds not solid.
I have read the link given in your answer. However, it is not mentioned, whether the loop with max_concurrency is scheduled at run-time or compile-time.
