Many errors while SYCL-code compilation for FPGA on local system
- 3 years ago
Thank you for posting in Intel community forum and hope all is well.
Noted on the inconvenient faced, based on the explanation it seems that there are two possibilities of issues either on the host machine that is installation oneAPI or the sample codes that are causing the error. Leaning more toward the host machine, may I know where did you get the sample code from?
Would suggest perhaps to try and build the same sample code in our Intel Devcloud, instruction as the link below:
- https://devcloud.intel.com/oneapi/get_started/
If codes are building and running, this would rule out the issues on codes.
As for the host machine installation, would recommend to refer to the getting started guide below:
Assuming you are using the CLI to run the sample, suspecting that maybe the system variable are not set or corrupted.
Hope that clarify
Best Wishes
BB
Assume that you have managed to find the solution on system variable not set as mention, with no further clarification on this thread, it will be transitioned to community support for further help on doubts in this thread. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support.
Thank you for the questions and as always pleasure having you here.
Best Wishes
BB
