Many errors while SYCL-code compilation for FPGA on local system
- 3 years ago
Thank you for posting in Intel community forum and hope all is well.
Noted on the inconvenient faced, based on the explanation it seems that there are two possibilities of issues either on the host machine that is installation oneAPI or the sample codes that are causing the error. Leaning more toward the host machine, may I know where did you get the sample code from?
Would suggest perhaps to try and build the same sample code in our Intel Devcloud, instruction as the link below:
- https://devcloud.intel.com/oneapi/get_started/
If codes are building and running, this would rule out the issues on codes.
As for the host machine installation, would recommend to refer to the getting started guide below:
Assuming you are using the CLI to run the sample, suspecting that maybe the system variable are not set or corrupted.
Hope that clarify
Best Wishes
BB
Hope that clarify
Best Wishes
BB
- Vladislav-Butko-bvo3 years ago
It's more likely that "the system variable are not set" because sample code are compiled successfully on DevCloud. But I didn't test this guess and do migrate on DevCloud.
