Local OneAPI FPGA synthesis
Hello, I am trying to run FPGA hardware synthesis locally on my own device but i ran into problem
I get error message while trying to build Simple_Add with hw option :
Error: Internal Compiler Error. BSP specified project name dcp, but dcp.qpf does not exist.
I am wondering if i should create such file or it is caused by wrong versions of software.
I am using Quartus Pro 19.3 and Intel OneApi release 2021.1-beta07.
Is there any problem with these softwares or the problem is elsewhere?
- AnilErinch_A_Intel
Hi ,
Can you mention which device you are trying to run the OneAPI compilation.
Is this a custom board and which is the BSP is being used.
Thanks and Regards
Anil
Hi ,
In addition to the previous response please let us know the following
1. Whether the FPGA add on is installed.
https://software.intel.com/content/www/us/en/develop/tools/oneapi/components/fpga.html
2. Whether the init script has been run ? It has to be run every session.
The command is as shown below
source /opt/intel/inteloneapi/setvars.sh
Please let us know the response to the queries.
Thanks and Regards
Anil
Hi ,
Please let us know whether the instructions as below
"1. Whether the FPGA add on is installed.
Helped in addressing the issue.
Thanks and Regards
Anil
- DanielDl
1.) I have installed oneAPI base toolkit only as i found no specific standalone download for FPGA addon.
I guess it should be enough.2.)Yes i have added execution of this script to .bashrc such i do not have to do it manually.
I looked at the produced files and i was able to find .prj folder that contains *.v files and some other, but i do not fully understand build process, so i do not know if thats a good sign.
Hi ,
Can you share the make file / commands which you are using for building and details about FPGA device you are targeting the code to be run.
Thanks and Regards
Anil
- DanielDl
Hello , I am trying to compile project provided by OneApi example projects, specialy said FPGA_tutorial_Compile_Flow.
I created example project in Eclipse on Virtual Ubuntu machine. But Eclipse Build Target for fpga was not doing anything so i built fpga_emu target. In build folder there was makefile which contained target for fpga and i used command "make fpga" to build for FPGA. and then the error mentioned in first message appears.
Is it possible that thiscrash could be cused by lack of memory?
- Penteado__Mauricio
Hi folks,
I have the exactly same problem on my side:
Error: Internal Compiler Error. BSP specified project name dcp, but dcp.qpf does not exist.I am trying to run the Intel's Simple_Add example on OneApi 2021.1-beta07.
My card is a DE10-Standard with Cyclone V. I am using the BSP provided by terasic.
Please, let me know if anyone can help me.
Mauricio G Penteado.
Hi ,
Can you please share the make file and your source code directory structure , if the problem is still persisting.
Thanks and Regards
Anil
