ytrezq
2 years agoIs it possibe to request low‐level Oneᴀᴘɪ or OpenCl language extensions ?
Hello, I don’t know if it’s the right place nor if it’s possible but I was thinking in C/C+ we have the asm() keyword/function or compiler interstics like __builtin_ia32_pcmpistri128() for doing a st...
JohnShanly
2 years agoPerhaps the RTL library support would do what you want:
- ytrezq2 years ago
In the C analogy using ʀᴛʟ would be equivalent to using a plain .asm file where in .asm you have to care if you use a register or memory which can be handled automatically with a asm/interstic statement. In the ꜰᴘɢᴀ case, this means you still have to clock manually the design.
So this is lower level.
Also, as far I understand, Verilog/ᴠʜᴅʟ code can’t use Sycl code…
