Mopplikus
3 years agoIntel HLS - simulating the design with ModelSim
Hello, I have generated a design using Intel HLS, and now I'd like to look at the corresponding wave graphs in ModelSim / QuestaSim. Since for the co-simulation a test-bench has already been generat...
Mopplikus
3 years agoHello,
I found the solution to my issue. For instance, I needed to add the -ghdl flag to the i++ command, which then generates a .wlf file in the verification folder, which I can then open with ModelSim. For future reference, to get the wave graph, you have to choose the instance of your top level component, and then in the Objects tab you can add the waves for the signals you need.
I'm encountering another issue now however; for instance, no matter the target frequency I specify, in the wave graph it is always set to 1000MHz, even if I override it with the --clock flag when compiling or for the individual components with hls_scheduler_target_fmax_mhz(). How could I fix this?
-Mopplikus
