Balkesh
2 years agoHow to use Avalon-ST to Avalon-MM in msgDMA
Hello Sir, I want to know should i use Modular scatter Direct Memory Access IP in order to take coming data from Avalon Streaming and convert them to Avalon mm interface to store in memory. Should...
Wincent_Altera
2 years agoHi,
May I know you are referring to Agilex I-series or F-series ?
If I series you can get it via https://www.rocketboards.org/foswiki/Documentation/HPSExampleDesignForAgilex7ISeriesDeKit2xRTileAnd1xFTile
Else you can try to generate the example via IP catalog. (if available)
Wincent_intel
