MDavi68's avatar
MDavi68
6 years ago
Host channels arria 10 pac [DevCloud]
I am interested in work with the Intel host pipes in Arria10 FPGA, that is available in the a10gx_hostpipe bsp. In the Intel DevCloud I only see the a10_pac, which does not have channels. Is it possible to get access to a bsp with that feature?
Thanks in advance
    • MDavi68's avatar
      MDavi68
      Thanks, Kenny_t for your answer, The documentation link only refers to Arria10 PAC, as my devcloud_login. Currently, I am using the node s005-n004. I've tried to list the available nodes but I can't differentiate between arria GX and PAC devices .The "properties" don't make a difference, it just shows arria10. I accessed a couple of them, and all are PAC devices. how I can identify an arria10GX node? El vie., 19 jun. 2020 a las 6:14, Intel Forums (<[email protected]>) escribió:
      • Dr_FPGA's avatar
        Dr_FPGA
        Same here. I am very interested getting OpenCL host pipes working with our application. BTW I tried to get access to "right Arria 10 cloud" and got yet another DevCloud account w/o GUI tools and Tcl scripts.
  • TTwom's avatar
    TTwom
    I am also trying to setup host pipes and would very much appreciate it if there was a node that supported it.
    • Lawrence_L_Intel's avatar
      Lawrence_L_Intel
      I'm curious what application you want to run on the Arria 10 GX board that the A10 PAC cannot support? We can investigate installing that board, but it could take a month or longer as we need another server blade - all are occupied with PAC boards.
      Larry
      • Dr_FPGA's avatar
        Dr_FPGA
        Why just not to add Software support for host pipes to Intel PAC card? This should be less than a month, it is just a software update!
        Our application is confidential at the moment. However, the convenience of pumping data via host channels has advantage of having much less code than handling ping-pong buffers with events, etc. And we all for less code and conveniences, correct?
  • KennyT_altera's avatar
    KennyT_altera
    We do not receive any response from you to the previous question/reply/answer that I have provided. Please post a response in the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
