MDavi68
6 years agoHost channels arria 10 pac [DevCloud]
Hi, I am interested in work with the Intel host pipes in Arria10 FPGA, that is available in the a10gx_hostpipe bsp. In the Intel DevCloud I only see the a10_pac, which does not have channels. Is it ...
KennyT_altera
6 years agoWhich nodes you are trying to access?
You might access to the wrong nodes for it, try to look for Intel® Arria® 10 GX FPGA Development Kit nodes.
You may check this https://github.com/intel/FPGA-Devcloud/tree/master/main/Devcloud_Access_Instructions#devcloud-access-instructions. If the nodes is not there, I will request them to setup one for it.
MDavi68
6 years agoThanks, Kenny_t for your answer,
The documentation link only refers to Arria10 PAC, as my devcloud_login. Currently, I am using the node s005-n004.
I've tried to list the available nodes but I can't differentiate between arria GX and PAC devices .The "properties" don't make a difference, it just shows arria10. I accessed a couple of them, and all are PAC devices. how I can identify an arria10GX node?
El vie., 19 jun. 2020 a las 6:14, Intel Forums (<[email protected]>) escribió:
