HLS with quartus-compile enabled failed using a library created from an RTL module using VHDL-2008
I have created a VHDL Entity with IEEE.FIXED_PKG and made a library from it to use it in HLS components. I can emulate the component and do also RTL simulation with it. But when I try to invoke the i++ compiler with --quartus-compile flag, the synthesis fails because in the generated QSF file is not the vhdl-2008 version enabled. The result is it cannot find the IEEE.FIXED_PKG library. It uses the standard vhdl-1993 verison. Is there a way to change to the vhdl-2008 version? Synthesis directive in the VHLD file does not help. Here is the command I use, using Qartus 20.4 Pro and also Quartus 21.2 Pro versions:
i++ -march=Arria10 libRTLMod.a --fpga-only -ghdl --quartus-compile -I ./lib -I./hdl test_comp_fpga_qii.o
HLS run Quartus compile failed
The debug.log files reports this:
Error (13785): VHDL Use Clause error at moving_avg.vhd(5): design library "ieee" does not contain primary unit "fixed_pkg" File: ...moving_avg.vhd Line: 5
In the test_comp_fpga_qii/quartus directory is a quartus_compile.qsf file. Here would help setting a global assignment like this:
set_global_assignment -name VHDL_INPUT_VERSION VHDL_2008
Is there a way to guide the compiler to add such a line using the appropriate VHDL version?
- BoonBengT_Altera
Moderator
Hi @thj,
Thank you for posting in Intel community forum, hope all is well and apologies for the delayed in response.
If I understand the situation correctly, there are a way that you can set in the quartus to specify to the compiler on which VHDL version to use.Please do look into the settings in the quartus project under Assignments -> Settings -> Compiler Settings -> VHDL Input
You would be able to chose the inputs there, please do let us know if that helps to clarify your doubts.Best Wishes
BB
- thj
Hello BB,
Thank you for your answer.
At command line, I can invoke the i++ compiler with the compile flag --quartus-compile. That invokes the quartus synthesis tools (quartus compiler) with the fitter. The outcome of the fitter is important for me to estimate the resource consumption properly.
What I did is indeed to start the quartus project manually and changing the VHDL input to the correct version. Then I start the synthesis flow again. Now I investigate if the output is meaningful, because the i++ compile flow is broken, and I fear the quartus compile flow (fitter) optimizes away a lot because of not connected signals in the resulting hardware design.
By the way, I have instantiated an HDL object as described in the Intel High Level Synthesis Compiler Pro Edition Reference Manual Chapter 11.4. The reason is to investigate the resource consumption between a version written in HLS compared to one written in VHDL and the effect of the maximum throughput I can get when I insatiate the HDL object within my component function. For me the C++ (HLS, DPC++) features are very interesting, because that enables template metaprogramming as well and could be quite useful to create powerful designs with a minimum of resource consumption on FPGA hardware, too.
Thomas
