HLS run Quartus compile FAILED with following error "qsh_flowengine.tcl" unsuccessful
Hi @jlrainbolt,
After analyzing the init_hls logs, it seems that the setup are ok.
However after revisiting the previous debug logs, my suspect here is that the fitter in quartus crushes might be due to RAM limit, hence would recommend to also checked on the memory usage for your compilation machine.
Would recommend to reboot your machine and launched another compilation, and monitor the RAM usage, at the same time try to free up or minimiza the RAM usage for your compilation machine when the compilation happens.
Note: Sometime placement and routing processes might be memory intensive.
Best Wishes
BB
- jlrainbolt3 years ago
Hi @BoonBengT_Altera ,
Thank you for this suggestion. I rebooted the computer and ran the tutorial exactly as I did in this post while monitoring the RAM usage. The system RAM usage topped out at 9 GB. The computer has 125 GM of RAM, so unfortunately I don't think this is the problem.
Thank you,
Lacey
