HLS Compiler 24.2 - missing libraries in generated simulation files
Those links are super old. Please use the 24.2 documentation: 5. Licensing Intel® FPGA Software
I have used the LM_LICENSE_FILE variable successfully on my windows laptop (although I use local licenses).
You may generate a 0-cost Questa FSE license and use it locally: 5.3. Acquiring Free, No-Cost Licenses (intel.com).
- NoahHuguenin2 years ago
Okay, so I went back to using FSE (this time the one within Quartus Pro 24.2) with a local license (through LM_LICENSE_FILE).
Indeed, the misaligned version of Quartus and Questa was the cause of the problem. There is no longer a problem with missing libraries.
Next I will try to use Questa FE with the server license through the LM_LICENSE_FILE variable. Nevertheless that is somewhat off-topic so I think we can consider that this issue is solved
Thank you kindly for your support!
