NoahHuguenin
2 years agoHLS Compiler 24.1 error - aocl-clang.exe - dll entry point not found
Good day, I recently installed HLS Compiler 24.1 together with Quartus Prime Lite 23.1std in order to do the first HLS tests. I installed Visual Studio 2017 Community and the latest version of Mic...
- 2 years ago
Thanks Noah. Please install Quartus 23.1lite, then add HLS as an 'upgrade', paying attention to step 3 of the Getting Started Guide. Make sure you remove/rename any version of HLS that exists in 23.1lite; I spoke with some people in engineering and the error you're seeing might appear if HLS 24.1 pro happens to pick up the libraries from HLS 23.1std.
