HLS Compiler 24.1 error - aocl-clang.exe - dll entry point not found
- 2 years ago
Thanks Noah. Please install Quartus 23.1lite, then add HLS as an 'upgrade', paying attention to step 3 of the Getting Started Guide. Make sure you remove/rename any version of HLS that exists in 23.1lite; I spoke with some people in engineering and the error you're seeing might appear if HLS 24.1 pro happens to pick up the libraries from HLS 23.1std.
Hi @NoahHuguenin,
Thank you for posting in Intel community forum, hope all is well and apologies for the delayed in response.
Noted on the details of the error, a quick check on the installation path, did you managed to combine the installation path for Quartus Prime Lite and Intel HLS compiler together?
Could you possible share a screenshot of the path?
Also are you able to launch quartus lite and try to create a new project with CycloneV just to test on the quartus installation?
Hope to hear from you soon.
Best Wishes
BB
