Hello World Design Example Error (-1001)
I'm trying to run the hello world example, but when attempting to run the host executable from the hello world directory using the command:
CL_CONTEXT_EMULATOR_DEVICE_INTELFPGA=1 bin/hostI see the following error message:
ERROR: UNRECOGNIZED ERROR CODE (-1001)
Query for number of platforms failedSteps to Reproduce
After installing Intel Quartus Pro, I followed the steps in the documentation below, starting from "Installing a custom FPGA" board for a linux machine.
I skipped the Enabling Backwards Compatibility section and went to the Verifying Host Runtime Functionality via Emulation section.
I set QUARTUS_ROOTDIR_OVERRIDE to where quartus pro was installed to
[patrickjang@localhost hello_world]$ echo $QUARTUS_ROOTDIR_OVERRIDE
/home/patrickjang/intelFPGA_pro/18.1/quartusAs well as LD_LIBRARY_PATH
[patrickjang@localhost hello_world]$ echo $LD_LIBRARY_PATH
/home/patrickjang/intelFPGA_lite/18.1/hls/host/linux64/lib/:/home/patrickjang/intelFPGA_pro/18.1/hld/host/linux64/lib:/home/patrickjang/intelFPGA_pro/18.1/hld/board/nalla_pcie_hostch/linux64/lib:/home/patrickjang/intelFPGA_pro/18.1/hld/host/linux64/lib:/home/patrickjang/intelFPGA_pro/18.1/hld/board/nalla_pcie_hostch/linux64/libDownloaded the Hello World example project for linux and entered the directory
Compiled a kernel for emulation
[patrickjang@localhost hello_world]$ aoc -march=emulator -v device/hello_world.cl -o bin/hello_world.aocx
aoc: Environment checks are completed successfully.
aoc: Cached files in /var/tmp/aocl/patrickjang may be used to reduce compilation time
You are now compiling the full flow!!
aoc: Selected default target board p385a_mac_hostch_ax115
aoc: Running OpenCL parser....
aoc: OpenCL parser completed successfully.
aoc: Linking Object files....
aoc: Compiling for Emulation ....
aoc: Emulator Compilation completed successfully.
Emulator flow is successful.
To execute emulated kernel, invoke host with
env CL_CONTEXT_EMULATOR_DEVICE_INTELFPGA=1 <host_program>
For multi device emulations replace the 1 with the number of devices you wish to emulateI then built the host application using the make command.
Heres what's in my bin directory:
[patrickjang@localhost hello_world]$ ls bin
hello_world hello_world.32130.temp hello_world.aocr host
hello_world.32080.temp hello_world.aoco hello_world.aocx
Next, I run "aocl linkflags" but am unsure with what to do with this information. Here's the output.
[patrickjang@localhost hello_world]$ aocl linkflags
-L/home/patrickjang/intelFPGA_pro/18.1/hld/host/linux64/lib -lOpenCLFinally I run "env CL_CONTEXT_EMULATOR_DEVICE_INTELFPGA=1 bin/host, which shows the aforementioned error message below:
[patrickjang@localhost hello_world]$ env CL_CONTEXT_EMULATOR_DEVICE_INTELFPGA=1 bin/host
Here's my aocl list-devices and diagnosis output (the diagnose all doesn't return anything)
[patrickjang@localhost hello_world]$ aocl list-devices
Warning:
No devices attached for package:
[patrickjang@localhost hello_world]$ aocl diagnose allHere's how I setup my environment variables in my ~/.bashrc file
PATH=$PATH:$HOME/bin
export QUARTUS_ROOTDIR="/home/patrickjang/intelFPGA_pro/18.1/quartus"
export QSYS_ROOTDIR="/home/patrickjang/intelFPGA_pro/18.1/qsys/bin"
export INTELFPGAOCLSDKROOT="/home/patrickjang/intelFPGA_pro/18.1/hld"
export AOCL_BOARD_PACKAGE_ROOT=${INTELFPGAOCLSDKROOT}/board/nalla_pcie_hostch
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:$INTELFPGAOCLSDKROOT/host/linux64/lib:$AOCL_BOARD_PACKAGE_ROOT/linux64/lib
export PATH=$PATH:$INTELFPGAOCLSDKROOT/bin:$QUARTUS_ROOTDIR/bin:$QUARTUS_ROOTDIR/sopc_builder/bin
export QUARTUS_ROOTDIR_OVERRIDE="/home/patrickjang/intelFPGA_pro/18.1/quartus"Please let me know if there are any other details I can provide. Any help would be greatly appreciated. Thanks!
- HRZ
From what I remember, this error happens when you do not have a compatible icd file located in "/etc/OpenCL/vendors/". If you install the OpenCL SDK as root, the icd driver is automatically installed, but if you install as a non-root user, you will have to copy the driver manually under the root account. Look for the icd file in *quartus_install_dir*/hld/ and copy it to the aforementioned path.
- PJang
Hey, thanks for the response!
I definitely see the two icd files in my *quartus_install_dir*/hld directory (Altera.icd and Intel_FPGA_SSG_Emulator.icd). However when I peek into my /etc/ directory, both as a local user and root, I can't find any folder named OpenCL. Any idea why that directory might be missing and what I can do to resolve that? I'm on a RHEL 6 box if that helps.
- HRZ
That is expected if this is the first time you are installing an OpenCL SDK on your OS. Just create the folder yourself and copy both files there, that will very likely resolve your issue. Make sure everyone has read and execute access to the folder, though.
