PJang
7 years agoHello World Design Example Error (-1001)
I'm trying to run the hello world example, but when attempting to run the host executable from the hello world directory using the command: CL_CONTEXT_EMULATOR_DEVICE_INTELFPGA=1 bin/host I see ...
PJang
7 years agoHey, thanks for the response!
I definitely see the two icd files in my *quartus_install_dir*/hld directory (Altera.icd and Intel_FPGA_SSG_Emulator.icd). However when I peek into my /etc/ directory, both as a local user and root, I can't find any folder named OpenCL. Any idea why that directory might be missing and what I can do to resolve that? I'm on a RHEL 6 box if that helps.
HRZ
7 years agoThat is expected if this is the first time you are installing an OpenCL SDK on your OS. Just create the folder yourself and copy both files there, that will very likely resolve your issue. Make sure everyone has read and execute access to the folder, though.
