HBM - high band memory
want to add to my previous post :
your archive project works fine and compile successfully in my workspace ,
but when I try to create from scratch example design ( HBM location -top ) still I get error
Hi
good news!!
I found the root cause of the error :
Error(175001): The Fitter cannot place 1 UFIND4H_UIB, which is within High Bandwidth Memory (HBM2) Interface Intel FPGA IP ed_synth_hbm_0_example_design_altera_hbm_1961_g23n22y
It was my set_location_assignment pin clock to PIN_AR26 - when remove it the Quartus succeed to finish the Plan stage successfully
But , Why ? this is legal pin ?
In addition , when the HBM is located at the bottom there is no issue even the assignment of the PIN_AR26
Are there more problematic pins when the HBM locate at the top ?
- ymiler1 year ago
Contributor
Hi
I found the issue
the solution is here :
Place this reference clock input on the UIB_PLL_REF_CLK_00 pins while using the HBM2 device on the bottom of the FPGA, or the UIB_PLL_REF_CLK_01 pins while using the HBM2 on the top of the FPGA.
when I locate the right pin it works
