FPGA compile in oneapi
Hi, I was wondering how can I solve this mistake about it?
- DanielDl
I have the same problem.
Is there any update in dependency for build? In version 0.9 there was no problem, now i can't even compile demo examples for FPGA.
- AnilErinch_A_Intel
Hi ,
Can you provide the directory structure at which you are trying to run the compilation.
Like the present directory its peers , The parent directory of present directory and the peers of parent directory will do.
Thanks and Regards
Anil
- DanielDl
I already solved the problem by myself.
The issue is that in oneApi version 0.10 there has been a change in names. I was not aware of the change. The change is in path of header and in namespace name.- in both cases "intel" has been changed to "INTEL" in capitals. This caused compiler not to find correct instances of code.
