Gao__Chao
5 years agoFPGA compile in oneapi
Hi, I was wondering how can I solve this mistake about it?
AnilErinch_A_Intel
5 years agoHi ,
Can you provide the directory structure at which you are trying to run the compilation.
Like the present directory its peers , The parent directory of present directory and the peers of parent directory will do.
Thanks and Regards
Anil
DanielDl
5 years agoI already solved the problem by myself.
The issue is that in oneApi version 0.10 there has been a change in names. I was not aware of the change. The change is in path of header and in namespace name.- in both cases "intel" has been changed to "INTEL" in capitals. This caused compiler not to find correct instances of code.
