Facing Partial reconfiguration error, "Error(18853): Running Synthesis on a partial reconfiguration design at the implementation revision is illegal."
I'm trying to generate a GBS file for my custom AFU.
Once the build_synth folder is created by using "afu_synth_setup -- source /path/to/filelist.txt build_synth", I'm opening dcp.qpf(cd build_synth/build) in Quartus GUI and running compilation.
In Analysis and Synthesis, I'm getting the following error related to Partial Reconfiguration.
Technical Details:
Software : Quartus Prime Pro 17.1.1
FPGA : Intel Arria X (10AX115N2F40E2LG)
Any suggestions on resolving this error will be helpful.
Thank you.
- RichardT_altera
Hi, the error implies that we do not run synthesis on a partial reconfiguration design at the implementation revision.
AN 797: Partially Reconfiguring a Design could guide you on the compilation flow for PR design.
- UTech
Thank you for the document
