UTech
6 years agoFacing Partial reconfiguration error, "Error(18853): Running Synthesis on a partial reconfiguration design at the implementation revision is illegal."
Hi, I'm trying to generate a GBS file for my custom AFU. Once the build_synth folder is created by using "afu_synth_setup -- source /path/to/filelist.txt build_synth", I'm opening dcp.qpf(cd build_...
RichardT_altera
6 years agoHi, the error implies that we do not run synthesis on a partial reconfiguration design at the implementation revision.
AN 797: Partially Reconfiguring a Design could guide you on the compilation flow for PR design.
- UTech6 years ago
Thank you for the document
