dgaranda's avatar
dgaranda
2 years ago
Error while linking host code device code in sycl with icpx
Lately I have been trying to compile and link a sycl kernel which has the attribute reqd_work_group_size for FPGA hardware with the oneAPI toolkits, specifically the icpx compiler.
Basically, I modified the fast recompile tutorial of oneAPI samples (https://github.com/oneapi-src/oneAPI-samples/tree/main/DirectProgramming/C++SYCL_FPGA/Tutorials/GettingStarted/fast_recompile ) to make the sycl structures 2D dimensional and make the kernel to have a nd_range as well as the reqd_work_group_size kernel attribute.
Compiling and linking the kernel into a FPGA image works well, but when i link this image with the host code it crashes showing the next error:
[100%] Generating fast_recompile.fpga
/opt/intel/oneapi/compiler/2024.1/bin/icpx -fintelfpga -qactypes host.o kernel_image.a -o fast_recompile.fpga -I/home/diegog/oneAPI-samples/DirectProgramming/C++SYCL_FPGA/Tutorials/GettingStarted/fast_recompile/../../../include
libc++abi: terminating due to uncaught exception of type std::bad_alloc: std::bad_alloc
 #0 0x000056039960bd73 llvm::sys::PrintStackTrace(llvm::raw_ostream&, int) (/opt/intel/oneapi/compiler/2024.1/bin/compiler/clang-offload-wrapper+0x3afd73)
 #1 0x000056039960a232 llvm::sys::RunSignalHandlers() (/opt/intel/oneapi/compiler/2024.1/bin/compiler/clang-offload-wrapper+0x3ae232)
 #2 0x000056039960c504 SignalHandler(int) Signals.cpp:0:0
 #3 0x00007fc149201420 __restore_rt (/lib/x86_64-linux-gnu/libpthread.so.0+0x14420)
 #4 0x00007fc14903e00b raise /build/glibc-LcI20x/glibc-2.31/signal/../sysdeps/unix/sysv/linux/raise.c:51:1
 #5 0x00007fc14901d859 abort /build/glibc-LcI20x/glibc-2.31/stdlib/abort.c:81:7
 #6 0x0000560399715896 (/opt/intel/oneapi/compiler/2024.1/bin/compiler/clang-offload-wrapper+0x4b9896)
 #7 0x00005603996fe5db demangling_terminate_handler() cxa_default_handlers.cpp:0:0
 #8 0x0000560399715553 std::__terminate(void (*)()) cxa_handlers.cpp:0:0
 #9 0x0000560399716f36 (/opt/intel/oneapi/compiler/2024.1/bin/compiler/clang-offload-wrapper+0x4baf36)
#10 0x0000560399716ecf (/opt/intel/oneapi/compiler/2024.1/bin/compiler/clang-offload-wrapper+0x4baecf)
#11 0x0000560399716c28 operator new(unsigned long) (/opt/intel/oneapi/compiler/2024.1/bin/compiler/clang-offload-wrapper+0x4bac28)
#12 0x00005603995e6ca8 llvm::util::PropertyValue::PropertyValue(unsigned char const*, unsigned long) (/opt/intel/oneapi/compiler/2024.1/bin/compiler/clang-offload-wrapper+0x38aca8)
#13 0x00005603994758dd SymPropReader::getPropRegistry() (/opt/intel/oneapi/compiler/2024.1/bin/compiler/clang-offload-wrapper+0x2198dd)
#14 0x000056039946cc22 (anonymous namespace)::BinaryWrapper::createBinDesc(OffloadKind, llvm::SmallVector<std::__1::unique_ptr<(anonymous namespace)::BinaryWrapper::Image, std::__1::default_delete<(anonymous namespace)::BinaryWrapper::Image>>, 4u>&) ClangOffloadWrapper.cpp:0:0
#15 0x00005603994654de main (/opt/intel/oneapi/compiler/2024.1/bin/compiler/clang-offload-wrapper+0x2094de)
#16 0x00007fc14901f083 __libc_start_main /build/glibc-LcI20x/glibc-2.31/csu/../csu/libc-start.c:342:3
#17 0x0000560399461529 _start (/opt/intel/oneapi/compiler/2024.1/bin/compiler/clang-offload-wrapper+0x205529)
icpx: error: unable to execute command: Aborted (core dumped)
icpx: error: clang-offload-wrapper command failed due to signal (use -v to see invocation)
Intel(R) oneAPI DPC++/C++ Compiler 2024.1.0 (2024.1.0.20240308)
Target: x86_64-unknown-linux-gnu
Thread model: posix
InstalledDir: /opt/intel/oneapi/compiler/2024.1/bin/compiler
Configuration file: /opt/intel/oneapi/compiler/2024.1/bin/compiler/../icpx.cfg
icpx: note: diagnostic msg: Error generating preprocessed source(s).
Is there a way to compile this kernel like in the example, separating host and device code?
I leave down below the modified code of the fast_recompile files, as well as all the compilation messages printed.
host.cpp code
// Copyright Intel Corporation
// SPDX-License-Identifier: MIT
#include <iostream>
#include <vector>
#include <sycl/sycl.hpp>
#include <sycl/ext/intel/fpga_extensions.hpp>
#include "exception_handler.hpp"
// This code sample demonstrates how to split the host and FPGA kernel code into
// separate compilation units so that they can be separately recompiled.
// Consult the README for a detailed discussion.
//  - host.cpp (this file) contains exclusively code that executes on the host.
//  - kernel.cpp contains almost exclusively code that executes on the device.
//  - kernel.hpp contains only the forward declaration of a function containing
//    the device code.
#include "kernel.hpp"
using namespace sycl;
// the tolerance used in floating point comparisons
constexpr float kTol = 0.001;
// the array size of vectors a, b and c
constexpr size_t kArraySize = 64;
int main() {
  std::vector<float> vec_a(kArraySize*kArraySize);
  std::vector<float> vec_b(kArraySize*kArraySize);
  std::vector<float> vec_r(kArraySize*kArraySize);
  // Fill vectors a and b with random float values
  for (size_t i = 0; i < kArraySize; i++) {
    vec_a[i] = rand() / (float)RAND_MAX;
    vec_b[i] = rand() / (float)RAND_MAX;
  // Select either the FPGA emulator, FPGA simulator or FPGA device
#if FPGA_SIMULATOR
  auto selector = sycl::ext::intel::fpga_simulator_selector_v;
#elif FPGA_HARDWARE
  auto selector = sycl::ext::intel::fpga_selector_v;
#else  // #if FPGA_EMULATOR
  auto selector = sycl::ext::intel::fpga_emulator_selector_v;
#endif
  try {
    // Create a queue bound to the chosen device.
    // If the device is unavailable, a SYCL runtime exception is thrown.
    queue q(selector, fpga_tools::exception_handler);
    auto device = q.get_device();
    std::cout << "Running on device: "
              << device.get_info<sycl::info::device::name>().c_str()
              << std::endl;
    // create the device buffers
    buffer device_a(vec_a.data(), range<2>(kArraySize,kArraySize));
    buffer device_b(vec_b.data(), range<2>(kArraySize,kArraySize));
    buffer device_r(vec_r.data(), range<2>(kArraySize,kArraySize));
    // The definition of this function is in a different compilation unit,
    // so host and device code can be separately compiled.
    RunKernel(q, device_a, device_b, device_r, kArraySize, 16);
  } catch (exception const &e) {
    // Catches exceptions in the host code
    std::cerr << "Caught a SYCL host exception:\n" << e.what() << "\n";
    // Most likely the runtime couldn't find FPGA hardware!
    if (e.code().value() == CL_DEVICE_NOT_FOUND) {
      std::cerr << "If you are targeting an FPGA, please ensure that your "
                   "system has a correctly configured FPGA board.\n";
      std::cerr << "Run sys_check in the oneAPI root directory to verify.\n";
      std::cerr << "If you are targeting the FPGA emulator, compile with "
                   "-DFPGA_EMULATOR.\n";
    std::terminate();
  // At this point, the device buffers have gone out of scope and the kernel
  // has been synchronized. Therefore, the output data (vec_r) has been updated
  // with the results of the kernel and is safely accesible by the host CPU.
  // Test the results
  size_t correct = 0;
  for (size_t i = 0; i < kArraySize*kArraySize; i++) {
    float tmp = vec_a[i] + vec_b[i] - vec_r[i];
    if (tmp * tmp < kTol * kTol) {
      correct++;
  // Summarize results
  if (correct == kArraySize*kArraySize) {
    std::cout << "PASSED: results are correct\n";
  } else {
    std::cout << "FAILED: results are incorrect\n";
  return !(correct == kArraySize);
kernel.hpp code
void RunKernel(queue& q, buffer<float,2>& buf_a, buffer<float,2>& buf_b,
               buffer<float,2>& buf_r, size_t size,size_t wgs);
kernel.cpp code
// This file contains 'almost' exclusively device code. The single-source SYCL
// code has been refactored between host.cpp and kernel.cpp to separate host and
// device code to the extent that the language permits.
// Note that ANY change in either this file or in kernel.hpp will be detected
// by the build system as a difference in the dependencies of device.o,
// triggering a full recompilation of the device code.
// This is true even of trivial changes, e.g. tweaking the function definition
// or the names of variables like 'q' or 'h', EVEN THOUGH these are not truly
// "device code".
// Forward declare the kernel names in the global scope. This FPGA best practice
// reduces compiler name mangling in the optimization reports.
class VectorAdd;
               buffer<float,2>& buf_r, size_t size, size_t wgs){
    // submit the kernel
    q.submit([&](handler &h) {
      // Data accessors
      accessor a(buf_a, h, read_only);
      accessor b(buf_b, h, read_only);
      accessor r(buf_r, h, write_only, no_init);
      // Kernel executes with pipeline parallelism on the FPGA.
      // Use kernel_args_restrict to specify that a, b, and r do not alias.
      h.parallel_for<VectorAdd>(nd_range(range(size,size),range(wgs,wgs)),[=](nd_item<2> item) [[intel::kernel_args_restrict, sycl::reqd_work_group_size(16,16)]] {
        size_t i = item.get_global_id(0);
        size_t j = item.get_global_id(1);
        r[{i,j}] = a[{i,j}] + b[{i,j}];
/usr/bin/cmake -S/home/diegog/oneAPI-samples/DirectProgramming/C++SYCL_FPGA/Tutorials/GettingStarted/fast_recompile -B/home/diegog/oneAPI-samples/DirectProgramming/C++SYCL_FPGA/Tutorials/GettingStarted/fast_recompile/build_reqd_2 --check-build-system CMakeFiles/Makefile.cmake 0
make -f CMakeFiles/Makefile2 fpga
make[1]: Entering directory '/home/diegog/oneAPI-samples/DirectProgramming/C++SYCL_FPGA/Tutorials/GettingStarted/fast_recompile/build_reqd_2'
/usr/bin/cmake -E cmake_progress_start /home/diegog/oneAPI-samples/DirectProgramming/C++SYCL_FPGA/Tutorials/GettingStarted/fast_recompile/build_reqd_2/CMakeFiles 6
make -f CMakeFiles/Makefile2 CMakeFiles/fpga.dir/all
make[2]: Entering directory '/home/diegog/oneAPI-samples/DirectProgramming/C++SYCL_FPGA/Tutorials/GettingStarted/fast_recompile/build_reqd_2'
make -f CMakeFiles/displayHostCompileCommand.dir/build.make CMakeFiles/displayHostCompileCommand.dir/depend
make[3]: Entering directory '/home/diegog/oneAPI-samples/DirectProgramming/C++SYCL_FPGA/Tutorials/GettingStarted/fast_recompile/build_reqd_2'
cd /home/diegog/oneAPI-samples/DirectProgramming/C++SYCL_FPGA/Tutorials/GettingStarted/fast_recompile/build_reqd_2 && /usr/bin/cmake -E cmake_depends "Unix Makefiles" /home/diegog/oneAPI-samples/DirectProgramming/C++SYCL_FPGA/Tutorials/GettingStarted/fast_recompile /home/diegog/oneAPI-samples/DirectProgramming/C++SYCL_FPGA/Tutorials/GettingStarted/fast_recompile /home/diegog/oneAPI-samples/DirectProgramming/C++SYCL_FPGA/Tutorials/GettingStarted/fast_recompile/build_reqd_2 /home/diegog/oneAPI-samples/DirectProgramming/C++SYCL_FPGA/Tutorials/GettingStarted/fast_recompile/build_reqd_2 /home/diegog/oneAPI-samples/DirectProgramming/C++SYCL_FPGA/Tutorials/GettingStarted/fast_recompile/build_reqd_2/CMakeFiles/displayHostCompileCommand.dir/DependInfo.cmake --color=
Scanning dependencies of target displayHostCompileCommand
make[3]: Leaving directory '/home/diegog/oneAPI-samples/DirectProgramming/C++SYCL_FPGA/Tutorials/GettingStarted/fast_recompile/build_reqd_2'
make -f CMakeFiles/displayHostCompileCommand.dir/build.make CMakeFiles/displayHostCompileCommand.dir/build
[ 16%] To run the host code compile manually:
 /opt/intel/oneapi/compiler/2024.1/bin/icpx -fintelfpga -Wall -qactypes -DFPGA_HARDWARE -c /home/diegog/oneAPI-samples/DirectProgramming/C++SYCL_FPGA/Tutorials/GettingStarted/fast_recompile/src/host.cpp -o host.o -I/home/diegog/oneAPI-samples/DirectProgramming/C++SYCL_FPGA/Tutorials/GettingStarted/fast_recompile/../../../include
/usr/bin/cmake -E cmake_echo_color --cyan
[ 16%] Built target displayHostCompileCommand
make -f CMakeFiles/displayFPGALinkCompileCommand.dir/build.make CMakeFiles/displayFPGALinkCompileCommand.dir/depend
cd /home/diegog/oneAPI-samples/DirectProgramming/C++SYCL_FPGA/Tutorials/GettingStarted/fast_recompile/build_reqd_2 && /usr/bin/cmake -E cmake_depends "Unix Makefiles" /home/diegog/oneAPI-samples/DirectProgramming/C++SYCL_FPGA/Tutorials/GettingStarted/fast_recompile /home/diegog/oneAPI-samples/DirectProgramming/C++SYCL_FPGA/Tutorials/GettingStarted/fast_recompile /home/diegog/oneAPI-samples/DirectProgramming/C++SYCL_FPGA/Tutorials/GettingStarted/fast_recompile/build_reqd_2 /home/diegog/oneAPI-samples/DirectProgramming/C++SYCL_FPGA/Tutorials/GettingStarted/fast_recompile/build_reqd_2 /home/diegog/oneAPI-samples/DirectProgramming/C++SYCL_FPGA/Tutorials/GettingStarted/fast_recompile/build_reqd_2/CMakeFiles/displayFPGALinkCompileCommand.dir/DependInfo.cmake --color=
Scanning dependencies of target displayFPGALinkCompileCommand
make -f CMakeFiles/displayFPGALinkCompileCommand.dir/build.make CMakeFiles/displayFPGALinkCompileCommand.dir/build
[ 33%] To run the FPGA link compile manually:
[ 33%] Built target displayFPGALinkCompileCommand
make -f CMakeFiles/displayDeviceCompileCommand.dir/build.make CMakeFiles/displayDeviceCompileCommand.dir/depend
cd /home/diegog/oneAPI-samples/DirectProgramming/C++SYCL_FPGA/Tutorials/GettingStarted/fast_recompile/build_reqd_2 && /usr/bin/cmake -E cmake_depends "Unix Makefiles" /home/diegog/oneAPI-samples/DirectProgramming/C++SYCL_FPGA/Tutorials/GettingStarted/fast_recompile /home/diegog/oneAPI-samples/DirectProgramming/C++SYCL_FPGA/Tutorials/GettingStarted/fast_recompile /home/diegog/oneAPI-samples/DirectProgramming/C++SYCL_FPGA/Tutorials/GettingStarted/fast_recompile/build_reqd_2 /home/diegog/oneAPI-samples/DirectProgramming/C++SYCL_FPGA/Tutorials/GettingStarted/fast_recompile/build_reqd_2 /home/diegog/oneAPI-samples/DirectProgramming/C++SYCL_FPGA/Tutorials/GettingStarted/fast_recompile/build_reqd_2/CMakeFiles/displayDeviceCompileCommand.dir/DependInfo.cmake --color=
Scanning dependencies of target displayDeviceCompileCommand
make -f CMakeFiles/displayDeviceCompileCommand.dir/build.make CMakeFiles/displayDeviceCompileCommand.dir/build
[ 50%] To run the device code compile manually:
 /opt/intel/oneapi/compiler/2024.1/bin/icpx -fintelfpga -Wall -qactypes -DFPGA_HARDWARE -fintelfpga -qactypes -Xshardware -Xstarget=de10_agilex:B2E2_8GBx4 -Xsclock=50MHz -Xsseed=2 -reuse-exe=/home/diegog/oneAPI-samples/DirectProgramming/C++SYCL_FPGA/Tutorials/GettingStarted/fast_recompile/build_reqd_2/fast_recompile.fpga -fsycl-link=image /home/diegog/oneAPI-samples/DirectProgramming/C++SYCL_FPGA/Tutorials/GettingStarted/fast_recompile/src/kernel.cpp -o kernel_image.a -I/home/diegog/oneAPI-samples/DirectProgramming/C++SYCL_FPGA/Tutorials/GettingStarted/fast_recompile/../../../include
[ 50%] Built target displayDeviceCompileCommand
make -f CMakeFiles/fpga.dir/build.make CMakeFiles/fpga.dir/depend
cd /home/diegog/oneAPI-samples/DirectProgramming/C++SYCL_FPGA/Tutorials/GettingStarted/fast_recompile/build_reqd_2 && /usr/bin/cmake -E cmake_depends "Unix Makefiles" /home/diegog/oneAPI-samples/DirectProgramming/C++SYCL_FPGA/Tutorials/GettingStarted/fast_recompile /home/diegog/oneAPI-samples/DirectProgramming/C++SYCL_FPGA/Tutorials/GettingStarted/fast_recompile /home/diegog/oneAPI-samples/DirectProgramming/C++SYCL_FPGA/Tutorials/GettingStarted/fast_recompile/build_reqd_2 /home/diegog/oneAPI-samples/DirectProgramming/C++SYCL_FPGA/Tutorials/GettingStarted/fast_recompile/build_reqd_2 /home/diegog/oneAPI-samples/DirectProgramming/C++SYCL_FPGA/Tutorials/GettingStarted/fast_recompile/build_reqd_2/CMakeFiles/fpga.dir/DependInfo.cmake --color=
Scanning dependencies of target fpga
make -f CMakeFiles/fpga.dir/build.make CMakeFiles/fpga.dir/build
[ 66%] Generating host.o
[ 83%] Generating kernel_image.a
/opt/intel/oneapi/compiler/2024.1/bin/icpx -fintelfpga -Wall -qactypes -DFPGA_HARDWARE -fintelfpga -qactypes -Xshardware -Xstarget=de10_agilex:B2E2_8GBx4 -Xsclock=50MHz\ -Xsseed=2 -reuse-exe=/home/diegog/oneAPI-samples/DirectProgramming/C++SYCL_FPGA/Tutorials/GettingStarted/fast_recompile/build_reqd_2/fast_recompile.fpga -fsycl-link=image /home/diegog/oneAPI-samples/DirectProgramming/C++SYCL_FPGA/Tutorials/GettingStarted/fast_recompile/src/kernel.cpp -o kernel_image.a -I/home/diegog/oneAPI-samples/DirectProgramming/C++SYCL_FPGA/Tutorials/GettingStarted/fast_recompile/../../../include
warning: -reuse-exe file '/home/diegog/oneAPI-samples/DirectProgramming/C++SYCL_FPGA/Tutorials/GettingStarted/fast_recompile/build_reqd_2/fast_recompile.fpga' not found; ignored
aoc: Compiling for FPGA. This process may take several hours to complete.  Prior to performing this compile, be sure to check the reports to ensure the design will meet your performance targets.  If the reports indicate performance targets are not being met, code edits may be required.  Please refer to the oneAPI FPGA Optimization Guide for information on performance tuning applications for FPGAs.
Thread model: posix
make[3]: *** [CMakeFiles/fpga.dir/build.make:65: fast_recompile.fpga] Error 1
make[2]: *** [CMakeFiles/Makefile2:144: CMakeFiles/fpga.dir/all] Error 2
make[2]: Leaving directory '/home/diegog/oneAPI-samples/DirectProgramming/C++SYCL_FPGA/Tutorials/GettingStarted/fast_recompile/build_reqd_2'
make[1]: *** [CMakeFiles/Makefile2:151: CMakeFiles/fpga.dir/rule] Error 2
make[1]: Leaving directory '/home/diegog/oneAPI-samples/DirectProgramming/C++SYCL_FPGA/Tutorials/GettingStarted/fast_recompile/build_reqd_2'
make: *** [Makefile:147: fpga] Error 2
  • Hi @dgaranda,
    Thank you for posting in Intel community forum, hope all is well and apologies for the delayed in response.
    Noted on he details explanation on the mention code, please do provide us some time to look into the request by running some simulation replication.
    Appreciate the patients, will get back as soon as gotten some updates.
    Best Wishes
    BB
  • Hi @dgaranda,
    I was able to compile the source code you posted. I want to check:
    • Are you using the the CMakeLists.txt from the code sample? Or did you modified it (other than file names)
    • What version of the compiler are you using ? (icpx --version and aocl version)
    • What's your compilation target (FPGA_DEVICE)?
    -Kevin
  • dgaranda's avatar
    dgaranda
    Hi @Kevin_Xu_Intel,
    The CMakeLists.txt is modified, but does not affect the FPGA target.
    The icpx version and aocl version is 2024.1.0. I put down below the output of icpx -v and aocl version.
    diegog@unicornio:~$ icpx -v
    Thread model: posix
    Found candidate GCC installation: /usr/lib/gcc/x86_64-linux-gnu/9
    Selected GCC installation: /usr/lib/gcc/x86_64-linux-gnu/9
    Candidate multilib: .;@m64
    Selected multilib: .;@m64
    diegog@unicornio:~$ aocl version
    aocl 2024.1.0.1097aa05bafa5450f9d5ca1475d35f5295a7b2fb (Intel(R) FPGA SDK for OpenCL(TM), Version 2024.1.0 Build 1097aa05bafa5450f9d5ca1475d35f5295a7b2fb Pro Edition, Copyright (c) 2024 Intel Corporation)
    And my target device is the board DE10-Agilex from Terasic ( https://www.terasic.com.tw/cgi-bin/page/archive.pl?Language=English&CategoryNo=142&No=1252#contents). The exact string passed to -DFPGA_DEVICE is
    de10_agilex:B2E2_8GBx4.
    Diego
    • Feng-Y-28's avatar
      Feng-Y-28
      Hi dgaranda
      May I get your environment set for DE10_Agilex?
      My issue was stuck for half a month without process.
      Could you give me the following enviro information, which can run the generated bitstream on the FPGA:
      • oneAPI DPC++ base toolkit version
      • Quartus Prime version
      I tried the 24.2 and 24.1 base toolkits, but all failed. Can your 2024.1 oneapi toolkit work successfully with DE10_Agilex? If so, I would appreciate your reply to my question.
      Feng
  • Hi @dgaranda,
    Suspecting there might be an incorrect compilation target specify.
    May I know where did you get the target device from?
    As mention board are from Terasic, is it correct to say you gotten the BSP from Terasic as well?
    As for the compilation flag target device option available, below link have the mention details:
    - https://www.intel.com/content/www/us/en/docs/oneapi-fpga-add-on/developer-guide/2024-1/fpga-compilation-flags.html
    Best Wishes
    BB
  • Hi @dgaranda,
    Good day, just following up on the previous clarification.
    By any chances did you managed to look into it?
    Hope to hear from you soon.
    Best Wishes
    BB
  • Hi @dgaranda,
    Greetings, unfortunately as we do not receive any further clarification/updates on the matter, hence would assume challenge are overcome. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. For new queries, please feel free to open a new thread and we will be right with you. Pleasure having you here.
    Best Wishes
    BB
