Error while linking host code device code in sycl with icpx
Hi @Kevin_Xu_Intel,
The CMakeLists.txt is modified, but does not affect the FPGA target.
The icpx version and aocl version is 2024.1.0. I put down below the output of icpx -v and aocl version.
diegog@unicornio:~$ icpx -v Intel(R) oneAPI DPC++/C++ Compiler 2024.1.0 (2024.1.0.20240308) Target: x86_64-unknown-linux-gnu Thread model: posix InstalledDir: /opt/intel/oneapi/compiler/2024.1/bin/compiler Configuration file: /opt/intel/oneapi/compiler/2024.1/bin/compiler/../icpx.cfg Found candidate GCC installation: /usr/lib/gcc/x86_64-linux-gnu/9 Selected GCC installation: /usr/lib/gcc/x86_64-linux-gnu/9 Candidate multilib: .;@m64 Selected multilib: .;@m64 diegog@unicornio:~$ aocl version aocl 2024.1.0.1097aa05bafa5450f9d5ca1475d35f5295a7b2fb (Intel(R) FPGA SDK for OpenCL(TM), Version 2024.1.0 Build 1097aa05bafa5450f9d5ca1475d35f5295a7b2fb Pro Edition, Copyright (c) 2024 Intel Corporation)
And my target device is the board DE10-Agilex from Terasic ( https://www.terasic.com.tw/cgi-bin/page/archive.pl?Language=English&CategoryNo=142&No=1252#contents). The exact string passed to -DFPGA_DEVICE is
Hi dgaranda
May I get your environment set for DE10_Agilex?
My issue was stuck for half a month without process.
Could you give me the following enviro information, which can run the generated bitstream on the FPGA:
- oneAPI DPC++ base toolkit version
- Quartus Prime version
I tried the 24.2 and 24.1 base toolkits, but all failed. Can your 2024.1 oneapi toolkit work successfully with DE10_Agilex? If so, I would appreciate your reply to my question.
Feng
