Error opening AFC: insufficient privileges
I have FPGA integrated into compute nodes. But, recently, I have note been able to use them. When I load the intel/2021.3.0 compiler the following messages are returned:
Error opening AFC: insufficient privileges Error opening AFC: insufficient privileges Error opening AFC: insufficient privileges Error opening AFC: insufficient privileges Error opening AFC: insufficient privileges
Or other times it returns:
Failed to configure device acl0:pac_ed00001|BSP_UNLOADED|PASSED Failed to configure device acl0:pac_ed00001|BSP_UNLOADED|PASSED Failed to configure device acl0:pac_ed00001|BSP_UNLOADED|PASSED Failed to configure device acl0:pac_ed00001|BSP_UNLOADED|PASSED
What does it means? And how should I fix it?
- aikeu
Hi lcruz,
Sorry for late respond. May I know some additional information from you regarding the below:
- Which tools you are using? IOFS? oneAPI? OPAE?
- Are you using intel devcloud to compile the design?
- Can you share more details on the design or command used to compile the project?
- Are you running the command with root access?
Aik Eu
- aikeu
- aikeu
Hi lcruz,
We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Aik Eu
- ndevenish
This sounds very similar to the issue I had https://community.intel.com/t5/Intel-High-Level-Design/Configuring-for-non-root-user-access-without-quot-Error-opening/m-p/1402918#M2603 - this turned out to be that my user didn't have sufficient permissions to read/write from the raw devices.
So either running the tooling as root worked or (preferably) changing the device permissions might work.
Nick
