lcruz
4 years agoError opening AFC: insufficient privileges
I have FPGA integrated into compute nodes. But, recently, I have note been able to use them. When I load the intel/2021.3.0 compiler the following messages are returned:
Error opening ...
aikeu
4 years agoHi lcruz,
Sorry for late respond. May I know some additional information from you regarding the below:
- Which tools you are using? IOFS? oneAPI? OPAE?
- Are you using intel devcloud to compile the design?
- Can you share more details on the design or command used to compile the project?
- Are you running the command with root access?
Aik Eu
