Double Buffering on Intel FPGA?
Hi all,
I read the paper "Best-Effort FPGA Programming: A Few Steps Can Go a Long Way". They used HLS on Xilinx devices as example. Besides the normal optimization, I found the double buffering is interesting:
void aes(...) { ... }
void load(...) { ... }
void store(...) { ... }
void compute(...) { ... }
void kernel(char *data, int size) {
char buf_data[3][PE_NUM][PE_BATCH];
#pragma HLS array_partition var=buf_data complete dim=1
#pragma HLS array_partition var=buf_data cyclic=PE_NUM dim=2
for (int i=0; i < size/BATCH_SIZE; i++) {
switch (i % 3) {
case 0:
load(buf_data[0], data+i*BATCH_SIZE);
compute(buf_data[1]);
store(data+i*BATCH_SIZE, buf_data[2]);
break;
case 1:
load(buf_data[1], data+i*BATCH_SIZE);
compute(buf_data[2]);
store(data+i*BATCH_SIZE, buf_data[0]);
break;
case 2:
load(buf_data[2], data+i*BATCH_SIZE);
compute(buf_data[0]);
store(data+i*BATCH_SIZE, buf_data[1]);
break;
Can the Intel compiler successfully imply this pipeline? I tried this on compiler version 16 but it seems that the throughput improvement is very limited.
1 Reply
- MuhammadAr_U_Intel
Contributor
Hi, There is continuous improvements on HLS software with every release. I would suggest using the latest version of HLS compiler 18.1 to see what optimization/ pipelining are done by software. Thanks, Arslan
