Josh_Intel
4 years agoHello @AleCampla,
I was referring to the options of using a Package Manager as described here:
I'm not sure which distribution of Linux you're using, but for example, if you're using RHEL and YUM, you could install oneAPI with the following if the repository is setup properly:
yum install intel-oneapi-intelfpgadpcpp-custom-platforms-quartus20.2
Ideally this would be a temporary workaround to get you moving forward until we can resolve your registration issue.
- joeryan4 years ago
I am having this same problem with getting the intel-oneapi-intelfpgadpcpp-a10gx-s10sx package. I have also tried to install through yum, but it fails after downloading 109% (2.1Gb of the expected 1.9Gb log attached). I was able to install the intel-basekit using yum on the system.
Joe Ryan
