CRAM SEU detection and mitigation support with OpenCL/oneAPI
Thank you for replying @BoonBengT_Altera ,
I have just returned from vacation. This issue has not been resolved. The documentation you linked does not cover what I asked for.
I'm aware of the CRC_ERROR pin, as mentioned in the post above. I've confirmed the N520 board has hardware reading this pin, the only part left is intel's host code. I'm asking specifically about a function in intel's host code library for HLS development, noted below:
clSetDeviceExceptionCallbackIntelFPGA( cl_uint num_devices, const cl_device_id * devices, CL_EXCEPTION_TYPE_INTEL listen_mask, void (CL_CALLBACK * pfn_exception_notify)( CL_EXCEPTION_TYPE_INTEL exception_type, const void * private_info, size_t cb, void * user_data), void * user_data);
This function can be found in the header file at the following path:
.../intelFPGA_pro/21.4.0/hld/host/include/CL/cl_ext_intelfpga.h
I am looking for documentation on this specific function. Searching on google or intels own search function yields no results. I have not been able to find it mentioned anywhere in the documentation either.
The question is: What arguments must I pass to this function to catch all CRC exceptions?
Kind regards,
Lennart
