wan1
2 years agoCannot run vector-add on FPGA in Devcloud jupyterLab
Hi, I am trying to run vector-add on FPGA but failed. Here are steps I followed. Any help would be appreciate! 1: go to https://jupyter.oneapi.devcloud.intel.com/user I assume jupyterlab include t...
BoonBengT_Altera
Moderator
2 years agoHi @wan1,
Thank you for posting in Intel community forum, hope all is well and apologies for the delayed in response.
Seems that you have successfully compile the emulation flow.
And as for the full compilation which required hard, VM node that jyputerlab have access to does not have hardware connected to them, hence the failure of device not found.
You would need to connect to the devcloud via ssh which will allow you to select the desire VM node with hardware for the full compilation. Further instruction on how to connect to devcloud via ssh can be found below:
-https://devcloud.intel.com/oneapi/documentation/shell-commands/
Hope that clarify.
Best Wishes
BB
