At least one S10 system fails to launch X2Go
I have been testing our solution on the S10 platforms, part of which requires a web browser to view our demo UI. X2Go is the simplest solution for this currently (we'll look at tunneling later).
s005-n008 was the system assigned by devcloud_login. I was able to get around this by logging out of that system, running 'pbsnodes -s v-qsvr-fpga' to find a free S10 and ' qsub -q batch@v-qsvr-fpga -I -l nodes=s005-n009:ppn=2' to get a different available system.
I've also noticed differences in the system configurations (mostly minor, dealing with /opt installations). These systems should be cloned and up-to-date (wish they were Ubuntu as well - sigh).
- GrueMaster
Steps to reproduce:
- ssh devcloud
- pbsnodes -s v-qsvr-fpga|fgrep -A1 s005-n008 # verify system is free before next steps
- qsub -q batch@v-qsvr-fpga -I -l nodes=s005-n008:ppn=2 # to get an interactive shell
- (In a new terminal on your desktop)
- ssh -L 4002:s005-n008:22 devcloud # this establishes the X2Go tunnel
- Launch X2Go client per instructions.
- Observe that xfce4-session fails to launch.
The above steps work on other systems I have tested so far.
- BoonBengT_Altera
Moderator
Hi @GrueMaster,
Thank you for posting in Intel community forum and hope this message find you well.
We are still trying to investigate further on this, but as a high level analysis I am suspecting that it might be a missed in some configuration.
Please do refer to the following suggest in the link here to see if that works.Warm regards.
BB- GrueMaster
So, given the fact that it works on multiple other systems EXCEPT s005-n008, you thing it is something wrong with my local x2go setup? Really?
