At least one S10 system fails to launch X2Go
Steps to reproduce:
- ssh devcloud
- pbsnodes -s v-qsvr-fpga|fgrep -A1 s005-n008 # verify system is free before next steps
- qsub -q batch@v-qsvr-fpga -I -l nodes=s005-n008:ppn=2 # to get an interactive shell
- (In a new terminal on your desktop)
- ssh -L 4002:s005-n008:22 devcloud # this establishes the X2Go tunnel
- Launch X2Go client per instructions.
- Observe that xfce4-session fails to launch.
The above steps work on other systems I have tested so far.
- BoonBengT_Altera5 years ago
Moderator
Hi @GrueMaster,
Thank you for posting in Intel community forum and hope this message find you well.
We are still trying to investigate further on this, but as a high level analysis I am suspecting that it might be a missed in some configuration.
Please do refer to the following suggest in the link here to see if that works.Warm regards.
BB- GrueMaster5 years ago
So, given the fact that it works on multiple other systems EXCEPT s005-n008, you thing it is something wrong with my local x2go setup? Really?
Moderator
Hi @GrueMaster,
Apologies on the late response and also I missed out the noted mentioning it is working on other nodes.
After some investigation it seem that the particular mention nodes 's005-n008' are not supported with X2GO as of now. (i.e. a note can be found in the setup guide in end of section 6.1)
Just a quick clarification, any reason you are trying to access x2go in the mention nodes?Warm regards.
BB
