Altera PLL (cycloneV) getting locked to the wrong frequency.
I have generated a PLL with dynamic reconfiguration enabled.
Ref frequency = 160 MHz,
Target Frequency = 16 MHz.
before lock
reconfig_to_pll[63:0] = 0_3c000000
reconfig_to_pll[63:0] = 0_3c000001
after lock
reconfig_to_pll[63:0] = 0_10000003
reconfig_to_pll[63:0] = 0_10000002
It changes every half cycle of ref clk.
But after reset PLL is getting locked to 105.77 MHz. Though I am expecting it to get locked to 16 MHz. Is this behavior expected?
For experiment : I generated a PLL for 50 MHz ref clk . Target frequency 16 MHz. It is getting locked to correct frequency.
Attaching snapshot of the PLL behavior for 160 MHz ref_clk.
PS: Altera-pll ip core user guide doesn't give information about reconfig_to_pll signal. Please direct me to correct document.
- Rahul_S_Intel1
Hi ,
Can you please try to follow the below PLL reconfiguration document.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an661.pdf
- jAqui8
Hi Rsree,
Thanks for the reply!
I have followed that document.
I think the problem is with PLL IP. I tried generating PLL for reference frequency- 50 , 100, 105, 110, 160 MHz.
for fref 50 MHz : f tareget = 16 MHz --- PLL locked to ~16 MHz
for fref 100 MHz : f tareget = 16 MHz --- PLL locked to ~16 MHz
for above 100 MHz, ---pll is locking to some random frequency after reset.
PS: in all the above cases, the dynamic reconfiguration was enabled and connection between pll ip and reconfiguration block was made as per an661 document.
Jawed
- Rahul_S_Intel1
Hi ,
The above behavior is wired, I have you check the below . Or any glitch in the input
Are the RREF pins connected correctly with its own individual resistor to GND
Are VREF and termination of the I/O standards set correctly?
