Altera PLL (cycloneV) getting locked to the wrong frequency.
Hi Rsree,
Thanks for the reply!
I have followed that document.
I think the problem is with PLL IP. I tried generating PLL for reference frequency- 50 , 100, 105, 110, 160 MHz.
for fref 50 MHz : f tareget = 16 MHz --- PLL locked to ~16 MHz
for fref 100 MHz : f tareget = 16 MHz --- PLL locked to ~16 MHz
for above 100 MHz, ---pll is locking to some random frequency after reset.
PS: in all the above cases, the dynamic reconfiguration was enabled and connection between pll ip and reconfiguration block was made as per an661 document.
Jawed
- Rahul_S_Intel16 years ago
Hi ,
The above behavior is wired, I have you check the below . Or any glitch in the input
Are the RREF pins connected correctly with its own individual resistor to GND
Are VREF and termination of the I/O standards set correctly?
