Björne2
2 years agoAdvice on CNN inference on Agilex 7 using oneAPI
Greetings everyone, I'm tasked with porting an CNN trained with PyTorch to an Agilex 7 FPGA using HLS. I think the right tool for the job is oneAPI. Since this is not a completely novel task, I wond...
whitepau_altera
Contributor
1 year agoThanks Bjorne; I'll forward this to engineering, you may have found a report bug.
Björne2
1 year agoHello again. I might have solved my problem. Apparently the -Xstarget option should name a specific board and not an FPGA family.
- Feng-Y-281 year ago
Hi Bjorne
May I get your environment set for DE10_Agilex?
My issue was stuck for half a month without process.
Could you give me the following enviro information, which can run the generated bitstream on the FPGA:- oneAPI DPC++ base toolkit version
- Quartus Prime version
I tried the 24.2 and 24.1 base toolkits, but all failed.
Feng
