Access for Stratix 10 node
Currently I have an account to DevCloud, and I used oneAPI to implement my work with Stratix 10 board chosen.
However, it seems like I have to access Stratix 10 PAC node to run my work (instead of Stratix 10 oneAPI node), which I don't have access.
I tried to sign up for the c009-fpga group following the last section of this post
I kept running into the same error message telling me there can't be any special character in the input box, I have checked/retype many times and I can't tell if there was ANY special character.
Would someone please just add me to the c009-fpga group? My account number is u47712.
Have you try initialize the board?
You may refer to https://software.intel.com/content/www/us/en/develop/documentation/oneapi-programming-guide/top/programming-interface/fpga-flow/fpga-bsps-and-boards/fpga-board-initialization.html for more information.
- JohnT_Altera
May I know what is the selection that you are able to select when you input "devcloud_login"? Are you able to access the Stratix 10 OneAPI node? If no, what is the error observed?
John Tio
- jasonlin316
Hi, I am able to access the S10 oneAPI node and compile my work or run emulation, but I cannot run my program ( xxx.FPGA) on the node.
When my host code calls the kernel function, it shows:
" terminate called after throwing an instance of 'cl::sycl::runtime_error' what(): Native API failed. Native API returns: -42 (CL_INVALID_BINARY) -42 (CL_INVALID_BINARY). Aborted"
I think maybe I need to connect to the S10 PAC node instead to run the xxx.FPGA file?
- JohnT_Altera
The API node that you connected should have the Stratix 10 PAC card connected. You should be able to performed "aocl diagnose".
May I know if you program the FPGA before you proceed with the host code?
- jasonlin316
Hi, I run "aocl diagnose" and it passed, seems like there's no problem with The FPGA card.
May I ask what you mean by "program the FPGA" ?
I ran the following commands, not sure if this is what you meant:
$ dpcpp -fintelfpga ../src/fuse.cpp -c -o dev.o
$ dpcpp -fintelfpga -fsycl-link=image dev.o -o device_image.a -Xshardware -Xsboard=intel_s10sx_pac:pac_s10
$ dpcpp -fintelfpga ../src/host.cpp -c -o host.o
$ dpcpp -fintelfpga host.o device_image.a -o FUSE.fpga
I run the xxx.FPGA again, this time I got segmentation fault instead of (CL_INVALID_BINARY)
- JohnT_Altera
- jasonlin316
Thanks, I did not do initialize The FPGA before.
Now it does not show (CL_INVALID_BINARY) anymore.
It runs into segmentation fault though, I guess there are some issues in the kernel code? If so, I think I am good with this S10 board problem and should focus on debugging the kernel from now.
Thank you.
- JohnT_Altera
Glad to hear that the issue is resolved. Yes, I think the segmentation fault might be related to the kernel or your host code to kernel interface.
