Access for Stratix 10 node
- 5 years ago
Have you try initialize the board?
You may refer to https://software.intel.com/content/www/us/en/develop/documentation/oneapi-programming-guide/top/programming-interface/fpga-flow/fpga-bsps-and-boards/fpga-board-initialization.html for more information.
May I know what is the selection that you are able to select when you input "devcloud_login"? Are you able to access the Stratix 10 OneAPI node? If no, what is the error observed?
John Tio
- jasonlin3165 years ago
Hi, I am able to access the S10 oneAPI node and compile my work or run emulation, but I cannot run my program ( xxx.FPGA) on the node.
When my host code calls the kernel function, it shows:
" terminate called after throwing an instance of 'cl::sycl::runtime_error' what(): Native API failed. Native API returns: -42 (CL_INVALID_BINARY) -42 (CL_INVALID_BINARY). Aborted"
I think maybe I need to connect to the S10 PAC node instead to run the xxx.FPGA file?
