installation & licensing
10 TopicsRequest for RoHS & REACH for PNs 5CEFA7U19C8N, 5CEFA7U19C8NES, 5CEFA7U19C8NQS (Case 184674)
Hello Team, I hope this message finds you well. Could you please provide us with RoHS and REACH for the below PNs: 5CEFA7U19C8N 5CEFA7U19C8NES 5CEFA7U19C8NQS In case this is not your responsibility, please forward it to the proper personnel. Please feel free to contact me if you have any questions or concerns. We appreciate your help. Case (184674)1.5KViews0likes3Commentscannot run GitHub samples on OneAPI FPGA emulator
I recently installed Ubuntu version 22.04 on my Mac2018. After the installation, I successfully installed the Intel® oneAPI Base Toolkit (Base Kit) along with the FPGA Support Package for the Intel oneAPI DPC++/C++ Compiler. However, I cannot compile the program on the FPGA emulator although I tried the recommended configurations by following Intel's documentation. The error shows below. wanyu@wanyu-MacBookPro15-1:~/Desktop/vector-add/build$ make fpga_emu [ 50%] Linking CXX executable ../vector-add-usm.fpga_emu OpenCL platform ID is empty OpenCL platform name is empty Failed to find any of these OpenCL platforms: Intel(R) FPGA Emulation Platform for OpenCL(TM) Intel(R) FPGA Emulation Platform for OpenCL(TM) (preview) llvm-foreach: icpx: error: fpga compiler command failed with exit code 14 (use -v to see invocation) make[3]: *** [src/CMakeFiles/vector-add-usm.fpga_emu.dir/build.make:97: vector-add-usm.fpga_emu] Error 14 make[2]: *** [CMakeFiles/Makefile2:159: src/CMakeFiles/vector-add-usm.fpga_emu.dir/all] Error 2 make[1]: *** [CMakeFiles/Makefile2:192: src/CMakeFiles/fpga_emu.dir/rule] Error 2 make: *** [Makefile:163: fpga_emu] Error 2 Could you kindly provide guidance on the specific configurations or steps that need to be performed during the installation or post-installation to enable FPGA emulator support? Thank you for your time and support. I look forward to your response. Thank you, Wanyu1.3KViews0likes0CommentsWifi Card Drivers
Hello, o have problem with my laptop.i cant connect into wifi , cus it shows the problem with driver, before it has working veru well. I didnt use laptop anout half year ... some1 would tell me what I havw to do. Becouse I have no option to repair it becouse no net. And I couldnt download any drivers... I try to configure it my self. But tthis is to hard ... also ive made it working for 2 minute today ... and after that computer automatem restart... and still there is problem what i couldnt solo it. Please give me some info how could i fix this problem.1.7KViews0likes4CommentsLife cycle of 10M50DCF256A7G
May I ask the future availability of 10M50DCF256A7G? - How long is this particular FPGA's life cycle up to? I have new program launched just by the end of this year and will be in full swing by the next... considering using this product from Intel. Thank you!Solved1.2KViews0likes3CommentsHow can I download/get device support file (.qdz) for Stratix II device & Quartus II v13.1?
I install the Quartus II v13.1 and try to open my design with Stratix II FPGA. It give me error "Cannot open project file, device support file not installed" I look in download center but find no "Quartus II device files (.qdz)"Solved7.9KViews0likes4Commentscyclone 10gx "10CX105YF672I5G"
Hello all, I'm new for this platform, My requirement is need to test all the example driver in cyclone 10GX NIOS 2 FPGA "10CX105YF672I5G" part number. I'm not able to find the example project to test the driver. Please if someone knows or having the driver kindly share it with me. Regards, Anujayan2.9KViews0likes12CommentsRE: OneAPI and FPGAs
I attended OneAPI training for FPGAs in August. It was focused on DPC++ but I need to get details about using it with AgileX. Where can I talk about this? I see no forums for FPGAs. I use Windows and I have not had problems with installing OneAPI and tools there but I'm stuck on a MacAir because Network is being upgraded. Right now, I need to get OneAPI installed on my Mac. I cannot verify where I put things on my machine and I need to clean it up to this properly. 1. Where/what are the default installs settings for OneAPI? I search on my mac but for some reason I cannot see the file system completely. This computer is not managed by policies...it's feral. 2. Can I just delete a folder to remove everything and start over? I know on windows, there's the registry but I don't know Mac that well to know if things are that connected. 3. My OpenVino LTS version is 2021 4, Build date: 29 Jun 2021 Let's start here...Solved2.4KViews0likes5CommentsoneAPI FPGA hardware error
When I tried to run oneAPI samples on devcloud, it shows error below, but I can run them before. I didn't make any changes. quartus_sh: error while loading shared libraries: libncurses.so.5: cannot open shared object file: No such file or directory Error: The patches required to compile for the target board (0.05dcp) is not installed for the following Quartus: /glob/development-tools/versions/oneapi/2021.3/inteloneapi/intelfpgadpcpp/2021.3.0/QuartusPrimePro/19.2/quartus/bin/quartus_sh dpcpp: error: fpga compiler command failed with exit code 1 (use -v to see invocation) make: *** [Makefile.fpga:30: vector-add-buffers.fpga] Error 14.3KViews0likes11Commentsgdb on FGPA DevCloud
Hello, I'm using the FPGA DevCloud, more specifically, the Arria 10 PAC Compilation and Programming with Development Stack 1.2.1. I need debugging tools like gdb, but unfortunately, it does not seem that gdb is installed. Could you install the debugging tools? Thanks! HongboSolved2.5KViews0likes3Comments
