Knowledge Base Article
Why is there D2H payload mismatch on GTS AXI MCDMA IP?
Description
Due to a problem in the Quartus® Prime Pro Edition software version 26.3 and earlier, the GTS AXI Multichannel DMA IP for PCI Express* might transmit D2H data associated with the wrong queue on AXI-Stream TX interface. As a result, the Host may receive data at an incorrect destination address, potentially causing transaction mismatches.
Resolution
This problem is scheduled to be fixed in a future release of the Quartus Prime Pro Edition software.
Updated 2 hours ago
Version 3.0
