Knowledge Base Article
Why is there a mismatch between the sideband information field of the Scalable Scatter-Gather DMA IP D2H ST responder descriptor and the error bit of the d2h_st_tuser signal?
Description
Due to a problem in the Quartus® Prime Pro Edition software version 25.1 and earlier, when Enable TUSER to SOP mapping feature for D2H_ST Port parameter is disabled and the D2H ST DMA data transfer is not aligned to the D2H ST device port data width, the Scalable Scatter-Gather DMA IP may observe incorrect sideband information (user-defined error) of the D2H ST responder descriptor as compared to the error bit of D2H AXI-ST Subordinate d2h_st_tuser input signal.
Resolution
The problem has been fixed starting with Quartus® Prime Pro Edition software version 25.1.1.
Updated 4 months ago
Version 5.0No CommentsBe the first to comment
