Knowledge Base Article
Why is the Intel® HDMI* IP RX vid_lock signal deasserted when the video timing geometry is inconsistent?
Description
Due to a problem with the Intel® HDMI* IP, the signal RX vid_lock may not assert if video timing geometry is inconsistent.
The HDMI RX IP checks for consistent HSYNC width, VSYNC width, Htotal, Hactive, Vtotal, and Vactive parameters across frames to qualify stable video and assert vid_lock.
If these video parameters are inconsistent across frames vid_lock is deasserted and vid_data, vid_hsync, vid_vsync, and vid_de are invalid.
Resolution
This problem is fixed in version 17.1 of the Intel® Quartus® Prime software.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
